Replacing Old Thermostat With new Analogue and Wiring Different
Andy in Sussex
by Andy in Sussex » Sat Apr 09, 2016 2:45 pm
Hi looking for help with replacing an old thermostat for new analogue but the wiring connections are marked differently.
Old connections are as follows:
Red: comm
Yellow: H
Blue: N
Brown: Across H and TL
New thermostat has:
L
3
2
N
Any help would be greatly appreciated
Andy
Re: Replacing Old Thermostat With new Analogue and Wiring Different
by ericmark » Sun Apr 10, 2016 12:09 pm
Each thermostat normally comes with a wiring diagram. To match one to other you need some extra info.
It would seem Blue = N = Neutral on old and new so that wire is easy enough.
The red - Com is likely the line and I would expect it will go to L
That leaves just the yellow - H wire which is very likely call for heat. It is likely 2 and 3 are the N/O and N/C contacts one is for heating the other for cooling but without more info can't help with which the yellow goes to.
Andy in Sussex
by Andy in Sussex » Tue Apr 12, 2016 4:16 pm
Thanks Eric for your reply.
Looking at the Drayton website for the new controller I have to put the call for heat to position 3 so will give this a go with the yellow wire and red wire to Comm
Andy
It is currently Mon Jan 13, 2025 2:05 am
