22mm Low Pressure Non Return Compression Valve Required
garfield59
by garfield59 » Sat Apr 09, 2016 3:03 pm
I am trying to locate a 22mm compression fit non-return valve that will open with gravity/tank feed rather than mains. No-one in my local builder's merchants knew there was such a thing and if I look online, the working pressure never seems to be specified.
Any suggestions welcome!
Many thanks,
Garfield
lets have a look
Re: 22mm Low Pressure Non Return Compression Valve Required
by lets have a look » Sun Apr 10, 2016 7:53 am
your post isn't very clear "gravity/tank feed rather than mains" ????
garfield59
by garfield59 » Mon Apr 11, 2016 7:37 am
lets have a look wrote:your post isn't very clear "gravity/tank feed rather than mains" ????
Thanks for the reply.
Sorry I wasn't very clear with my explanation. The valve will be going into the hot water supply to a shower and the hot water is a gravity feed from a tank. I'm told a lot of NRV's require mains pressure to open and so wouldn't be suitable. Does that make more sense?
Many thanks
Garfield
lets have a look
by lets have a look » Mon Apr 11, 2016 3:06 pm
yes it does,the only place I know that sells them are arrow valves they're called SPED Check Valve and Connector
garfield59
by garfield59 » Mon Apr 11, 2016 11:27 pm
Thanks very much, I'll give them a try. Will let you know how I get on.
Garfield
It is currently Sat Nov 23, 2024 5:59 pm
