Laying Wire Ouside Underground for Alarm for Metal Shed
fireside
by fireside » Tue Apr 12, 2016 1:02 pm
I have built a metal shed on concrete base. As so I can not operate gsm alarm due to the shed not allowing the signal to travel.
So to have it alarmed I have a wired home alarm which will allow me to designate a sensor to that zone.
So my question is...
How would I run a 6 core alarm wire 30m to the house?
I want to bury it underground to avoid it being tampered with.
What would I cover the wire with that is suitable to be in the ground without spending a fortune.?
At point of shed entry from wire coming out of the ground to shed, what connection could I use which I could bolt to shed, water and tamperproof?
Many thanks
Re: Laying Wire Ouside Underground for Alarm for Metal Shed
by ericmark » Thu Apr 14, 2016 3:16 pm
One can get special cable, but I would tend to put standard cable in a plastic pipe an old hose pipe for example as the proper stuff is a bit expensive.
fireside
by fireside » Mon Apr 18, 2016 9:00 am
ericmark wrote:One can get special cable, but I would tend to put standard cable in a plastic pipe an old hose pipe for example as the proper stuff is a bit expensive.
Thanks ericmark
It is currently Mon Dec 23, 2024 2:50 pm
