Pump on Mains and Hot With Mains Regulator
TimT
by TimT » Mon Apr 18, 2016 6:08 pm
I live in a block of flats. We have excellent (turn the taps on and stand back excellent!) cold mains direct into each property, no tanks in lofts etc. The hot is supplied via a copper immersion cylinder in each flat - the pressure being from a small header tank atop the hot tank. Hot pressure is next to useless, in fact, it is useless.
My neighbour has just had a pump fitted in his flat to boost the hot, and to achieve this had a regulator fitted to the cold mains inlet which I presume lowers the pressure at which it enters the pump. The pump is connected to both hot and cold supplies to his taps/shower.
My neighbour now has excellent pressure on his hot water, and cold.
I had quotes to fit hot water systems in my flat (unvented, pressured I think?) and the cost ran to £1500 to £1800. I was then thinking of going for a thermal storage solution as it is apparently a better system, and the cost went over £2000
My neighbour got his pump done at mates rates circa £200.
I was told I could have a pump fitted by a plumber who quoted me for the works above. Not allowed, illegal or similar words were used.
Facts please? I can't find the definitive answer on Google, only something about pumps which boost the supply of cold. I just want to increase the pressue of my hot water so I can take a reasonably pleasant shower instead of doing piroettes under a drip every morning.
Thanks.
lets have a look
Re: Pump on Mains and Hot With Mains Regulator
by lets have a look » Tue Apr 19, 2016 9:13 am
Plumbing in your case is finding a solution,if any other members find fault with my solutions please be polite,give an alternative and don't question my qualifications as a plumber for 40 years.
is there enough room in the airing cupboard to fit a header tank that would be a cold feed only to the shower pump,connecting in the hot feed,
I am not sure sure about the pump your neighbour had fitted to the cold main even with a regulator as the pump is meant to suck water from a water tank,but if it works,what can I say but will it eventually damage the pump,
if there isn't room for another tank,maybe drill into the existing tank and connect the cold supply that way
It is currently Tue Jan 07, 2025 12:39 am
