Insulating Wooden Shed with DPM already installed between Frames and Cladding
julian46
by julian46 » Fri Apr 22, 2016 7:11 pm
I would like to insulate the sides of a shed which was built with a damp proof membrane (not breatheable) between the T & G cladding and the 3 x 2 frames. This ensures watertightness but, if I add insulation and then put another DPM on the inside, then any moisture would have nowhere to go.
Is there a solution to this problem? Should I make small perforations in the waterproof membrane to allow evaporation?
Any suggestions gratefully received.
Julian
Showing waterproof membrane installed before cladding was attached.
Re: Insulating Wooden Shed with DPM already installed between Frames and Cladding
by welsh brickie » Sat Apr 23, 2016 7:37 pm
rip it off and use a breathable membrane like Tyvek, it will rot otherwise
It is currently Mon Dec 23, 2024 1:24 am
