New Oven Tripping RCD When Turned up to 200 Degrees
sinedtomuch
by sinedtomuch » Sun Apr 24, 2016 4:13 pm
Hi all, new to the forum after leeching for so long!
Anyway some background information:
Replaced old oven due to broken grill element. The old oven had no issues besides the broken element. It was wired straight into the RCD, no plug/socket etc.
New oven fitted and wired up (correctly) however the main oven when I turn it too 200 degrees for example it will trip. But then I reset the RCD and it will work.
I'm assuming the cable used initially will be rated high enough to cope with the new oven as it was just a like for like replacement, double oven for double oven. Both outputs are near enough the same.
Any help is appreciated. Thanks.
Re: New Oven Tripping RCD When Turned up to 200 Degrees
by ericmark » Sun Jun 12, 2016 7:16 am
The mineral in the mineral insulated element will absorb moisture it is hygroscopy, if the seal at the end is damaged or if it has been in storage for a long time. The normally way to get them running is to connect to a non RCD protected supply and heat them up to drive off the moisture. However if new I would just return it as faulty.
It is currently Sun Nov 24, 2024 8:28 am
