Advice on Filling Large Holes in Load Bearing Wall for Hanging Shelves
Dauph
by Dauph » Fri Apr 29, 2016 4:31 pm
Greeting all!
I am trying to repair some floating shelves for a client.
They are poorly designed and fix by just leaving two screws protruding from the wall onto which the shelf slots .
The supplied screws were barely long enough to hit brick and the plaster is old and crumbly.
No surprise that the shelves failed!
I tried to use much longer screws but after drilling the holes and getting the screws in, I discovered the screw heads are to big to fit in the slot holes on the back of the shelf.
Now I have great big holes that I need to fill with something that I can drill and fix screws closer to the original sized ones that will support the weight (and more) of the shelves.
I was thinking of drilling out the holes with a 10 mm bit and filling with epoxy putty, but that stuff is quite pricey.
Anyone have any recommendations?
Many thanks
Re: Advice on Filling Large Holes in Load Bearing Wall for Hanging Shelves
by welsh brickie » Mon May 02, 2016 1:58 pm
cut a much bigger hole about 75mm in diameter and at least 30mm deep.
paint the area with a pva solution, and fill it with dry wall adhesive. Leave to set for 24hrs, sand it back level with the plaster, then drill your hole
It is currently Mon Dec 23, 2024 2:41 pm
