New LED Light to Replace Ceiling Rose in Kitchen
everton11
by everton11 » Wed May 11, 2016 9:57 pm
i bought a new LED LIGHT for kitchen, my problem theres 3 cables coming from ceiling. the new light fitting diagram show 1 cable from ceiling. also there is no connection cable in light to connect to ceiling, very confusing. thank you
everton11
Re: New LED Light to Replace Ceiling Rose in Kitchen
by everton11 » Thu May 12, 2016 11:43 am
my problem his 3 cables coming from ceiling where do all the wires go ? into my new light fitting.
by ericmark » Fri May 13, 2016 7:02 am
Under the British system you have two lines at the ceiling rose. Permanent line is for emergency lights and ceiling fans and is not used with most lamps, which only use the switched line.
It is currently Mon Jan 13, 2025 2:28 am
