What Wood to Replace the Surface of a Table Tennis Table
tobester70
by tobester70 » Fri May 13, 2016 11:08 am
Can anyone tell me what would be the best and most economical wood to use for a full sized table tennis table intended for outdoor use. I've considered sealing MDF or plywood but not sure if it will with stand outdoor scrutiny; moisture resistant MDF, but not sure if the surface is right for a ping pong ball; and, Marine Ply, but that's so expensive I may as well just buy a new table. It doesn't help that the dimensions required are 4 pieces at 764 x 1375mm, so 4 large sheets (@ 1220 x 2440) with lots of waste.
John the joiner
Re: What Wood to Replace the Surface of a Table Tennis Table
by John the joiner » Wed May 18, 2016 10:38 pm
Look at laminate faced medium density fibreboard comes in 10' x 5' sheets
It is currently Fri Jan 10, 2025 10:52 am
