by aaaplastering »
Fri Aug 17, 2007 11:21 pm
Hi AndyB,
Im not sure on your experiences in plastering/Rendering.
The easiest way for you I would say firstly to apply the render to the wall using a plastering trowel. (Say about a few sq. metres) to start with.
Let it firm up a bit, Then try using a featheredge, start from the bottom bringing up the featheredge in a zig zag motion.
When the render has almost firmed up use a lighty damp sponge float working in a curricular motion.
Just practice with it, rendering is a lot more difficult than plastering, Even for us pro`s it can be hard some times ;)
By the way are you using plastersizer in your mix? and applying pva to your walls first?
The best way i find to do your mix is by using 70 % cerment and 30 % sand, add some plastersizer, also try to aviod using sand that contans any clay.
Hope this helps Leigh. > link deleted see terms and conditions
