Worried I've Chased too Deep into Wall and Weakened it?
daveyboixxx
by daveyboixxx » Mon May 16, 2016 1:53 pm
Hi, just after some advice really.
I have done a 2.5 metre long horizontal cable chase.
I obviously didn't do enough research as I went around 30mm into the blocks.
The actual chase may not be this deep but the drill holes are. (I suppose this doesn't make much difference)
I'm just wondering what I can do to check if the wall is now weakened and how long it may take to show signs...
Thanks in advance
daveyboixxx
Re: Worried I've Chased too Deep into Wall and Weakened it?
by daveyboixxx » Mon May 16, 2016 6:52 pm
Further info
It's on an outside wall of a bungalow and the chase is around 25mm wide
I used bonding plaster to fill and then Easy fill on top
daveyboixxx
by daveyboixxx » Mon May 16, 2016 6:57 pm
The house is a bungalow and the chase is about 25 wide and filled with bonding plaster
lets have a look
by lets have a look » Tue May 17, 2016 6:35 am
Don't worry 30mm is fine
It is currently Mon Jan 13, 2025 2:07 am
