Adding a Letterbox or Letter Plate Through the Wall
Jono14
by Jono14 » Tue May 24, 2016 9:12 pm
Hi I am having a new front door fitted but the design of the door does not lend itself to having a letter plate in it . The options are fix a letter box on the wall outside or my preferred option is put a letter plate on the wall with a sleeve going through a cavity wall . That way my post will be inside .
I am a little concerned with cold bridging ( cold air meeting warm air and forming condensation ) has anybody had any experience in this area ? I was going the build a box on the inside and insulate it .
Many thanks
Re: Adding a Letterbox or Letter Plate Through the Wall
by welsh brickie » Fri May 27, 2016 8:06 pm
use plastic to form the sleeve, and expanding foam to fill in around it.
Jono14
by Jono14 » Fri May 27, 2016 11:32 pm
Was thinking of using ply to form the sleeve ?
It is currently Mon Dec 23, 2024 4:40 pm
