Help needed with installing 2 Busch Dimmers
maxabelard
by maxabelard » Sat May 28, 2016 3:04 pm
Have just moved to Germany, and have a room with a double-gang system, the lower is a rotary dimmer which controls the lights in the kitchen, the upper is a double rocker switch that simply turns living-room lights on or off. So, I want to replace the double-rocker switch with dimmer as well. I went and bought the same type of Busch dimmer as the one that controls the kitchen lights and tried to fit it, the problem is that I now have the new rotary dimmer fitted, but when you turn it on, it switches both kitchen and living-room lights on. Moreover, it is dimming the living-room; and the other Dimmer for the kitchen does not dim, it only switches the light on or off. So I have two dimmers, one works as on/off switch for both Dimmers (don't want this, want them to be independent) and dims itself, but other Dimmer will not switch on/off independently and does not dim!!? The existing wiring was 1 black wire and 2 yellow wires coming into top double-rocker, and 1 black wire coming into rotary Dimmer. Between both dimmer and rocker was a single brown traveler wire crossing between. I have tried simply to replicate the wiring but to no avail. Any help would be gratefully appreciated. The kitchen lights ….4 x 30 watts. The living room light 4x60 watts
Notes on photos:
(i) Front view of Busch Dimmers: Original wiring was as the photo shows, except that the rocker switch on the left (now the new dimmer) had both yellow wires going to it (see photo). I changed this as dimmer were not dimming, and placed wire across to second dimmer, which briefly made both dimmers work. (ii) Front Overhead view of Dimmers: the orange wire in photos is in fact the Black wire (extended). (iii) The rear-view of the original Rocker switch (to Kitchen, no. 5 on block) had Brown wire going to Top Far Right (right of the ‘L’ ) next to which was the Black wire. I hope this explains things a bit better.
Many Thanks Max
Re: Help needed with installing 2 Busch Dimmers
by ericmark » Mon May 30, 2016 3:02 am
I would think you need a German forum, this one is British and our system may work with same voltage but we use a different system to control lights and wire sockets. German sockets in UK don't comply with our regulations.
maxabelard
by maxabelard » Mon May 30, 2016 11:39 am
Hi ericmark,
Yes, you right it appears so. I was hoping you might be able to tell something of what is going on from wiring.
As far as I understand, only 1 of the rocker's is in use and controls the living-room light, and the dimmer controls the Kitchen. Seeing that there were 2 faceplates (Dimmer & Rocker) connected by a single frame I assumed that they both had their own live, but I believe that they are sharing the source live. So, my question now is, can I install 2 individual dimmers (1 already there) which both share the same live, without them interfering with each other? Thanks again for your help. P.s. I don't as yet speak German, so difficult with the Forums here; also my experience so far is that they are not too forthcoming with this info, and currently I am not in a position to pay the 300 bucks quoted by local Electrician.
by ericmark » Tue May 31, 2016 5:14 pm
RS Components it seems stock the dimmers you want to used so http://uk.rs-online.com/web/p/products/ ... AuMd8P8HAQ the link should take you to an English instructions.
It would seem unlike UK systems both line and neutral go to the switch.
It is currently Mon Jan 13, 2025 2:40 am
