External Boundary 9 Inch Wall Needing Straps Restraints
bikerchris
by bikerchris » Wed Jun 08, 2016 10:53 am
Hi all,
I hope you can help a little bit, I've got a 9 inch boundary wall about 3 metres high, which I want to make about 2 metres high. It returns around the back garden and is on 3 sides, enclosing the garden. The rear wall is hanging outwards quite a bit, so I thought about metal strapping it at the corners (on the inner face). I just wondered where I can get the straps from - I've looked at wickes, screwfix and jewsons and all I can see are straps with long bits and then a short return. I thought that straps should probably be about 450 or 600mm in one direction and the same again in the other?
Look forward to any comments.
Cheers,
Chris
collectors
Re: External Boundary 9 Inch Wall Needing Straps Restraints
by collectors » Wed Jun 15, 2016 9:23 am
You can either buy some flat iron & bend it yourself or see if you have a local metal fabricator or blacksmith to make you some up.
bikerchris
by bikerchris » Fri Jun 17, 2016 6:27 pm
thank you for that, I've bought some L shape brackets, which are around 3 foot by 4-6 inches. They have plenty of holes in so I'm hoping that some raw plugs / long screws will do the job.
collectors wrote:You can either buy some flat iron & bend it yourself or see if you have a local metal fabricator or blacksmith to make you some up.
bikerchris
by bikerchris » Sat Jun 25, 2016 12:49 pm
Just so you all know, here's one of them installed. I used 2 inch bolts / rawplugs located as near to the centre of each brick as possible.
Strap metal 9 inch wall corner
bikerchris
by bikerchris » Sat Jun 25, 2016 12:50 pm
Sorry, meant to add that I'm doing another 2 of these, 1 a few feet from the ground level and another one at roughly head height.
It is currently Wed Jan 15, 2025 7:05 am
