Rockwool Cladding Panels for Kitchen Extension
taffbats
by taffbats » Thu Jun 16, 2016 3:29 pm
Hi chaps
New boy here so please be gentle with me.
I have built a single storey kitchen extension using hollow concrete blocks dry stacked and then filled the cores with concrete so effectively a solid wall, I am now looking at how to insulate and finish the outside of the building, and because I already have them could I clad the outside with 80mm rockwool steel clad sandwich panels and the to finish batten and slate over? If so would I need a vapour barrier anywhere or could I rely on the panels if I foil tape up the joins? Also do I need to leave a gap between the panels and the block or try to butt them together?
See pic attached of what I'm thinking about.
Thanks for your time.
Kev
It is currently Mon Dec 23, 2024 1:46 am
