Rust Coming Through From Angle Bead
Ben Lane
by Ben Lane » Wed Aug 15, 2007 1:31 pm
Hello
I have just had the walls of my porch skimmed. After allowing the plaster to dry i have painted the walls. The two main walls were skimmed. The two small wall returns that 'frame' the door (if that is a good description) were not skimmed as they were in pretty good nick, except that on painting the main walls and the returns rust is coming through the paint from the angle bead on one of the returns. Is there a simple way of sorting without replacing the bead (as it is only a problem on a small section of the beads length). Something like rub down, treat with XYZ, repaint.
Thanks in advance
Ben[/img]
It is currently Fri Nov 22, 2024 11:02 am
