Loose Hanging Door and now Crack has Appeared
jonnyhayes97
by jonnyhayes97 » Sun Jun 26, 2016 10:02 pm
Hello, I am new to this forum and hope to learn and help as much as possible in the future. I am currently a bit unsure about a job at home, my bathroom door is hanging on by the one bottom hinge. This wasn't a problem in the past as i'd simply just change the loose screws from the top hinge to larger screws. However now a crack has appeared at the top of the door and the holes are much larger than they should be. I was wondering if there is any way of maybe filling in the crack but also I need a way to secure the door to the hinge without changing the position of the hinge as I would prefer not to chisel out the door frame. If anybody has any ideas on how I could repair this I would appreciate it a lot :)
It is currently Fri Jan 10, 2025 7:52 am
