Concrete Framework for a Pizza Oven
PHSYT
by PHSYT » Fri Jul 01, 2016 3:01 pm
I'm building a pizza oven that requires me to build a concrete frame / hearth stand (instructions are american and state that standard 8’ x 8” x 16” and 8” x 8” x 8” concrete hollow blocks are used; see image)
i have not found any of these type in my local DIY place but i have found FIBOLITE, an ultra lightweight load bearing block (100 x 440 x 215mm). Lengths and height aside, the width is half that of the hollow blocks.
The instructions im using can be found on the following link
http://www.outdoorpizzaovens.ca/pdf/Pompeii_eBook.pdf (pages 22-31 relate to the frame)
the Fibolite is on the following link
http://www.jparrboro.co.uk/fibolite-con ... 2x16632747
My question is, should i use 2 layers of the Fibolite to make the same width of the hollow blocks or are they designed in such a way that one layer will suffice?
It is currently Fri Sep 20, 2024 6:49 am
