Magnetic Plate on Bath Panel Help Needed
Ukiwik
by Ukiwik » Wed Jul 06, 2016 4:27 pm
Hi there,
Have had issues with a V&B bath panel sliding down - it's essentially two heavy for the originally included magnets. Plumber was in contact with V&B who sent out a kit with stronger magnets and larger, thicker metal plates which he installed on the bath panel. While the strength of the magnet now seems plentiful we have a new issue whereby the metal plates are coming loose from the bath panel (one is off completely). I figured that rather than drag the plumber back out I should just be able to use a stronger adhesive however before I can do that I need to have clean plates.
I guess my question is two fold:
-What is the best method for removing the previous adhesive given that I don't really know what it is (tile adhesive? See attached)?
-What should be used instead to reattach them to the panel? I notice that the plumber didn't key the inside of the panel so perhaps it was doomed from the start?
Many thanks for your time!
Scott
It is currently Wed Jan 08, 2025 11:06 pm
