Is Low pressure or flow the cause of slow kitchen tap
Grahamggg
by Grahamggg » Tue Jul 12, 2016 1:25 pm
Suffering from low pressure and poor flow rate, currently get 4.5l/min from the kitchen tap. Water company has checked the boundary and that is fine. Could the attached picture be the problem? We have a combi boiler, could this be a pressure valve from old tank system? Thanks.
lets have a look
Re: Is Low pressure or flow the cause of slow kitchen tap
by lets have a look » Tue Jul 12, 2016 3:27 pm
take it out,think you have identified the problem
Grahamggg
by Grahamggg » Tue Jul 12, 2016 7:59 pm
lets have a look wrote:take it out,think you have identified the problem
Is it a pressure valve? Not seen anything like these and doesn't have a screw to alter pressure?
Should be fairly easy for a plumber to remove?
lets have a look
by lets have a look » Wed Jul 13, 2016 6:40 am
I haven't seen one either but suspect it is, the one below is a non return valve,
if the water switches off ok it would take about 20 mins to remove
Grahamggg
by Grahamggg » Wed Jul 13, 2016 12:41 pm
Great, I'll get it taken out and hopefully we'll get some pressure on our taps.
Thanks!
It is currently Sun Jan 05, 2025 4:27 am
