Wiring a new Lamp That has 9 Wires
biranb
by biranb » Thu Jul 14, 2016 11:57 am
Hello All
I have purchased a new light and have some difficulty fitting it and hope I can get some help
I have three of the following
I want to fit this to the following current light fitting
i have numbered the existing connections so hope some can tell me how to fit the 9 new wires I have
Regards
Bobby
kbrownie
Re: Wiring a new Lamp That has 9 Wires
by kbrownie » Thu Jul 14, 2016 9:52 pm
Terminals 1&2 are the switch lines, they come live when the switch is on and off when the switch is off. Just swap the brown of old lamp with brown of new.
Terminals 3,4,5 are the live loop, these are permanently live, and remain as they are.
Terminals 6,7.8 are the neutral loop, so just swap the blue of the existing lamp with the blue of the new one.
Then obviously the green/yellows are the CPC (AKA earth) and they are again swapped over like for like.
biranb
by biranb » Fri Jul 15, 2016 1:29 pm
Updated with correct images
Here is the old light
You can see where the brown and blue wires are connected to
I have removed the old light leaving the following
I have purchased a new light which has three lamps
In terms of connecting this do I
1) Connect the three blue wires to where the old light has its blue wire connected
2) Connect the three brown wires to where the old light has its brown wire connected
3) Connect the three earths to where the three green wires are connected
Is this safe?
I do not think I could fit another three wires to earth as there are three already
kbrownie
by kbrownie » Fri Jul 15, 2016 10:03 pm
Does this light have a cover/enclosure, as the fitting you are connecting to generally only has one pendant hanging from this.
biranb wrote:In terms of connecting this do I
Is this safe?
That would make all three lamps work, yes and it is safe providing you do this correctly and you can restrain all three sets of cables without causing stress to them.
biranb wrote:I do not think I could fit another three wires to earth as there are three already
I am unsure what you are trying to achieve by having this configuration from a single ceiling rose, could you please show me what the finished fitting looks like?
It is currently Sun Jan 12, 2025 2:04 am
