Which is Best for a Spring Hinged Shelf Fixed to Brick Wall
sambate1955
by sambate1955 » Mon Jul 18, 2016 6:31 pm
I'm fixing two spring hinged folding shelf support brackets to an interior brick wall to hold a 70" x 15" shelf, which will not carry a lot of weight. I will probably fit the supports about 15 inches in from either end (unless you think otherwise) and put on a shelf that is 1/2 inch thick. Which is best to use? Contiboard, plywood, MDF or chipboard? I'm concerned that the shelf will start to sag in the middle. My preference was contiboard as it is easy to clean and the price is comparitive with MDF and chipboard. Plywood seems a lot more expensive. I had considered buying a cheap flush door and cutting it down the middle, but I guess it will then be hollow at the cut edge (?) Thank you for any responses.
tileclipproman
Re: Which is Best for a Spring Hinged Shelf Fixed to Brick Wall
by tileclipproman » Mon Jul 25, 2016 11:11 pm
You will need a batten fixed to wall the length of the shelve.the door method
will be ok as you can turn the cut side to the wall .
It is currently Fri Jan 10, 2025 7:32 am
