Sludge in central heating system.
stevier66
by stevier66 » Wed Aug 15, 2007 5:55 pm
could anybody tell me how remove sludge from my central heating system . The system is piped in 8mm micro bore . There is a pump you can hire from a plumbers merchant so i am told ? but i am unsure what excactly what to do :?
GeckoGas
by GeckoGas » Sun Aug 26, 2007 12:51 am
Read up on "powerflushing"....
With microbore you'll need to work a bit harder to get it to flush properly as the pipes create a much higher resistance and of course, trap more sludge and debris as it travels around the system.
The Heating Doctor
by The Heating Doctor » Mon Aug 27, 2007 11:13 am
Once power flushed and cleaned, try having a Magna Clean or a Fernox Boiler Buddy fitted, this should reduce the risk of the sludge reforming
