Sewage pipe into 30mm basin pipe for basin drain
slimsi
by slimsi » Fri Jul 29, 2016 11:25 am
Hi, have been searching through the forums but can't quite find the answer to the problem I have at our new house...
In our downstairs loo in an extension there is a toilet and a basin in a unit, nothing unusual.
Drain for the basin is normal 30mm with trap which appears to hold water ok and this then goes down the back of the unit into a rubber seal which is over a toilet.sewage sized drain.
The seal on the 30mm pipe into the larger pipe is ok but not tight you can put a finger in easily between the seal and smaller pipe.
There is a nasty sewage smell in the downstairs loo and I dont think its coming from the waste in the basin, my question is two fold:
1, is the rubber seal suitable for this use indoors?
2. is there a better option for indoor use that will seal in smells better than a rubber one?
Simon
lets have a look
Re: Sewage pipe into 30mm basin pipe for basin drain
by lets have a look » Sat Jul 30, 2016 5:01 pm
More than likely they used a 40mm rubber seal,change it to a 32mm seal or if it's hard to get at seal it with sealant/mastic,
It is currently Sun Jan 05, 2025 4:26 am
