Wiring a 'switched' lampholder help needed
Vanesita2016
by Vanesita2016 » Sat Jul 30, 2016 10:27 pm
Could anyone assist with wiring a switched lampholder. I know the switch needs to break the 'live' wire, however, looking at the pictures of the product I have, could you describe exactly where the brown/live wire needs to go through please?
Many thanks.
kbrownie
Re: Wiring a 'switched' lampholder help needed
by kbrownie » Sun Jul 31, 2016 8:19 pm
Do the terminals have any markings on?
I would say (guess) that the permanent/common live would be terminated at the upper terminal of switch as pictured.
Then switch line would be terminated to the terminal at bottom of the switch.
The lamp will need a neutral, so that would also require identifying.
Vanesita2016
by Vanesita2016 » Fri Aug 05, 2016 9:33 am
Spot on! Thanks for your help.
kbrownie
by kbrownie » Sun Aug 07, 2016 4:56 pm
Thank you for the feedback.
It is currently Sun Jan 12, 2025 11:49 pm
