Filling old Pond Hole Ready to Lay Decking
Find information and help on all aspects of your garden pond e.g maintenance, pond life, construction etc....
Paulslay32
by Paulslay32 » Sun Jul 31, 2016 7:10 pm
I had a large koi pond in my garden. I have now broken all the concrete and bricks up and filled the hole with it. On front half of the hole i want to lay decking, but worried that if I put a footing in the broken concrete it is likely to move. I am looking for ideas on what to do to make Base safe for footings. The back is going to be a mixture of grass and slate.
Re: Filling old Pond Hole Ready to Lay Decking
by welsh brickie » Wed Aug 03, 2016 5:44 pm
I would use concrete pads, basically lay a concrete slab 450mm x 450mm on a mix of sand and cement, then cut some 4x4 timber posts and use them as legs fixed to your timer frame, you can adjust the legs to the desired height
It is currently Sun Dec 22, 2024 3:06 am
