Enlarge fireplace for electric fire and safety issues
lanham
by lanham » Sun Aug 14, 2016 10:18 am
I need to enlarge my fireplace to inset an electric fire. The hole needs to be 56cm wide and 52cm high and 12cm deep. I have seen and heard all sorts of horror stories about chimneys collapsing, the need to put a lintel in as a support etc. As a non builder I cannot see how cutting a hole 12cm deep could cause the chimney to fall down. What is the safe way to do it? Should a lintel be put in above the hole (before the hole is enlarged). If so, how high above the top of the hole should it go?
Brian
Re: Enlarge fireplace for electric fire and safety issues
by welsh brickie » Sun Aug 14, 2016 1:58 pm
for a structural job of this nature I would have a builder do it for you, Its alright for us to tell you how to do it, But there may be some unforeseen problem that could occur, that could cause major damage, so my best advice is that you call a professional tradesman.
lanham
by lanham » Sun Aug 14, 2016 3:20 pm
Thanks for your reply. Unfortunately, I am having a problem finding someone to do the job.
Brian
It is currently Mon Nov 25, 2024 7:58 am
