Drainage Systems in Converted Flat and do I Need to Correct it?
georgeflat
by georgeflat » Thu Aug 18, 2016 2:50 pm
Hi there,
I was wondering if anyone could help. We live in a flat in a converted terraced Victorian house built between 1896-1914 in east London. Our kitchen waste is connected to a rainwater pipe that drains into a gully and we wanted to make sure that this waste goes to the appropriate drain. We got a plumber around who said that properties of this age have a combined system as evident by the single manhood and that everything is in order.
We mentioned that the road has separate foul and surface water systems and he said that this is irrelevant as the property's drainage system is a combined one and that it would connect to water's authority foul system. For further reassurance he opened the manhole (this is very close to the gully that receives the kitchen waste) which definitely carried foul waste as there was toilet paper there (by there was a pipe running across it). He then run the tap having added dye and although this was draining in the gully neither the water or dye could be seen in the manhole. He was convinced however irrespective of that the property is served by a combined system and that the gull yin question connects to it.
The question I have is that do you think that this is correct? Could the dye not be seen as because the gully opens below what we saw but in the same manhole?
lets have a look
Re: Drainage Systems in Converted Flat and do I Need to Correct it?
by lets have a look » Fri Aug 19, 2016 5:53 pm
It would be unusual in a property of that age if it goes into a soakaway
georgeflat
by georgeflat » Sat Sep 03, 2016 12:47 pm
It's all good - another plumber confirmed
georgeflat
by georgeflat » Sat Sep 03, 2016 5:30 pm
It has been reviewed again and it's all in order.
It is currently Sat Jan 11, 2025 7:59 pm
