Water Pipe Soldering Questions for Replacing Water Pipes
stranger12
by stranger12 » Sun Aug 21, 2016 11:18 pm
Hi Guys,
I am changing some of my house pipes. I had a quote of 2.5k for changing few pipes and joining them using solder fitting.
I am competent enough to lay the pipes and use yorkshire fitting which has the solder ring in it. All that is needed is heat to release it .
I have managed to spend around £400 to get all pipes needed and changing them now.
Few questions I have are:
1. When a pipe is soldered and it doesn't leak or pop when tab is opened, can it pop or leak at later stage ? I am asking to find out if more instance my joint is dodgy then would I realise straight away ?
2. Would you use solder ring in addition to the the bit that is inside the yorkshire fitting ? I did it on one of the joints and some of it was sucked in and the rest ran down the pipe. I soon learned of the amount needed .
3. Input to my house is led 22m which is then straight away reduced to 15 . that is then fed to boiler and cold water. shouldn't boiler be 22m and cold tab 15m ?
lets have a look
Re: Water Pipe Soldering Questions for Replacing Water Pipes
by lets have a look » Mon Aug 22, 2016 6:37 pm
no 2 is the right way to solder,I cool mine off with a wet cloth, is the boiler a combi ?
stranger12
by stranger12 » Tue Aug 23, 2016 11:31 am
lets have a look wrote:no 2 is the right way to solder,I cool mine off with a wet cloth, is the boiler a combi ?
Have you ever had any problems with it bursting etc?
lets have a look
by lets have a look » Tue Aug 23, 2016 6:19 pm
No it's quite simple soldering,it's nice when you see the solder go into the fitting,
It is currently Sat Jan 11, 2025 10:16 pm
