Decking Frame Over Concrete Patio Help Needed
Ask questions and find answers on all your decking problems and issues
dt_diy
by dt_diy » Thu Aug 25, 2016 3:51 pm
Hi guys,
DIYer here looking to build my first deck and desperately need some advice!....
I have a concrete patio that I want to deck over.
The problem is, the concrete, while sound and stable, is only 135mm below the patio door sill, so I don't have enough room to use 6x2 joists.
I thought I could use 4x2 joists (actually 97mm x 45mm) and 28mm deck boards and pack the joists up off the concrete 10mm to allow water to drain.
I'd fasten the joists to the concrete using either 7.5 x 150mm concrete screws going straight through the joist, or attaching some angle brackets to each side of the joist and screwing to the floor that way.
Is this a good idea? Call me lazy, but I really don't fancy ripping up the patio so I can use 6x2s :)
If using 4x2s in this situation is ok, how often would I need to pack the joist up to prevent bowing and bouncing? Every 300mm or can I get away with wider gaps?
Thnaks for your help
Damian
Re: Decking Frame Over Concrete Patio Help Needed
by welsh brickie » Fri Aug 26, 2016 8:39 pm
you can place them at 400mm centres
It is currently Mon Jan 06, 2025 8:46 pm
