Hinge to Avoid Curtain Pole and Window Sill
dan237
by dan237 » Tue Aug 30, 2016 11:15 am
Hi, I am converting some ikea wardrobes to look fitted.
The wardrobe is tight in a corned but the door will not open properly due to the windowsill.
Is there a hinge I can but that will allow the door to open more, will a 153 degree hinge do the job?
Thanks in advance.
howrog
Re: Hinge to Avoid Curtain Pole and Window Sill
by howrog » Sun Nov 20, 2016 10:14 am
I think you will find the 165 degree hinge should be enough to clear the curtain pole and window sill, these people seem to do a reasonably priced one, it's H068B half way down the page.
www.romark.co.uk/products.aspx?m=cabine ... led-hinges
It is currently Fri Jan 10, 2025 7:04 am
