Water Hammer Problem and Installing Pressure Reducing Valve
richard368
by richard368 » Sun Sep 04, 2016 8:30 am
I have a water hammer problem and have been advised to install a pressure reducing valve at source, but would I get the same effect by simply turning down the main stop tap ? I have tried this but to eliminate the hammer but the pressure drops to a unusable condition,
Is the PRV just a measurable device for turning down the pressure or am I missing something ? my point is, what is the difference between installing a PRV and simply turning down the main stop tap ?
Richard
lets have a look
Re: Water Hammer Problem and Installing Pressure Reducing Valve
by lets have a look » Sun Sep 04, 2016 6:42 pm
None, water hammer usually comes from a ballvalve in the tank in the loft or a wc cistern
richard368
by richard368 » Sun Sep 04, 2016 8:41 pm
Thing is I'm on mains water, no tank, and I get hammer from the kitchen and bathroom taps as well as the toilet cistern ?
lets have a look
by lets have a look » Mon Sep 05, 2016 7:18 pm
Then change the inlet valve ( ballvalve) to the wc cistern and see if you have cured it
It is currently Sun Jan 05, 2025 3:32 am
