Britax 3 way tap no hot water?
Yabezag
by Yabezag » Sat Sep 10, 2016 6:27 pm
Hi all.. I am now fed up with this tap. Have changed the valve twice which is what Britax recommended. Not solved. Get a dribble of hot water only. Cold and drinking water are fine. Is the hot pipe blocked? Have opened the non return valve fully with the tap valve in and out. Same issue. Any ideas? Picture of tap and valve attached..
Thanks Gareth
It is currently Sun Jan 05, 2025 3:55 am
