Shower pump and mixer tap shower in flat
Sarahbrearley
by Sarahbrearley » Sun Sep 11, 2016 1:28 am
I have just moved into a high rise flat where there is a mixer tap with shower fitted to the bath when i went to turn tap on bath it only trickled out untill i move the thermostat side up but i am still not getting any hot water through and have been advised that there is a pump fitted under the bath but i can not hear any pump working?also i was advised it will only kick into action if my hot water is turned on for a few hours please could somone advise many thanks
lets have a look
Re: Shower pump and mixer tap shower in flat
by lets have a look » Mon Sep 12, 2016 5:56 pm
No you don't need to heat up the water, as long as the water is turned on and the tanks are full it should work, sounds like you need a new pump but check that it's switched on first.
Sarahbrearley
by Sarahbrearley » Mon Sep 12, 2016 11:43 pm
Many thanks for reply new one on order :-))
It is currently Sat Jan 11, 2025 8:00 pm
