Wiring up Switch After Moving it and Help Needed
Jimlad
by Jimlad » Fri Sep 16, 2016 10:38 am
I'm helping a neighbour he removed a wall switch...
We are in the Netherlands.
There are four wires (this is a switch for 1 set of spotlights)
Green = Live
Blue
2 x Black
I used a multimeter and I get no V~ ac reading from the green to any of the other wires..
I tested the green with a light up screwdriver and it is live.
Why do I get no V~ reading? (it gave 230v in nearby plug socket)
and
Shouldn't there be a max of three wires for a simple light switch?
Jimlad
Re: Wiring up Switch After Moving it and Help Needed
by Jimlad » Fri Sep 16, 2016 8:28 pm
anyone?
kbrownie
by kbrownie » Thu Sep 22, 2016 7:40 pm
If you do not have a point of reference to test a pole voltage indicator, you will not get a voltage reading, even if one or all conductors are live at the same voltage.
If you have a known path to earth or neutral, you can test using one of them to achieve a voltage value.
If none of the existing cores at the switch do not offer an alternative path from live, you will only get 0V, Even if they are live and carrying 230V.
by ericmark » Fri Sep 23, 2016 7:01 am
I would try a Dutch forum, they tend to follow German wiring methods not British, and in Britain we tend to use the ceiling rose as a junction box, when in rest of EU they tend to use the switch as a junction box. So better to ask in a non British forum.
It is currently Sun Jan 12, 2025 11:24 pm
