Drainage Gratings to Prevent Blockage for ACO Raindrain Channels
roger191141
by roger191141 » Thu Sep 29, 2016 10:38 am
ACO Raindrain channels are often fitted between patios and buildings. They work but the slotted gratings tend to act as leaf traps while actually allowing small leaves to pass through and block the system. What's needed is a perforated grating which ACO don't make for this system. Does anyone know of a perforated grating that would fit Raindrain channels? I can't find anything online.
Re: Drainage Gratings to Prevent Blockage for ACO Raindrain Channels
by welsh brickie » Sun Oct 09, 2016 7:05 pm
ACO have a sump filter section that is used to trap debris so it does not block the drain
It is currently Sun Nov 24, 2024 6:15 am
