Advice Needed on old Flat Roof to Pitched Roof Conversion
AdamD
by AdamD » Sat Oct 08, 2016 1:52 pm
hi,
I have just moved into a property which has had a flat roof to pitched roof conversion at some point in its history. The old flat roof, complete with felt, is still in the loft. I am now decorating the property and want to do some things like moving light fixtures or changing to spot lights etc. Normally I would just pop in the loft and run the required wiring to the new locations. But there is a 'roof' in the way.
How can I best go about getting access to the ceiling space under that roof. I'm wary of cutting holes for access as I don't know where the cables are routed. Is it best just to slice the whole old flat roof up and take it all out piece by piece?
It is currently Mon Dec 02, 2024 3:30 pm
