Static Water Left in Low Profile Shower Tray
eddyb
by eddyb » Mon Oct 17, 2016 11:17 pm
We've just had our loft done and the plumber has put a low profile shower tray in (145x80cm)
Water doesn't completely drain off this after a shower - small puddles get left in the corner nearest the drain.
The plumber says it may not be draining because of the size of the tray. This sounds a bit odd to me, but I was wondering if anyone else has had a similar experience?
The plumber swears it's level. I only have a small spirit level - and while the bubble is within the lines on the level it is touching the line on the side nearest the drain. (Hope that last bit makes sense).
Ed
It is currently Sat Jan 11, 2025 8:54 pm
