3 Phase Fused Distribution Box in and 63A RCD in Garage
Magnet
by Magnet » Fri Oct 28, 2016 10:29 pm
I have a 3 phase fused Distribution Box in my Garage , I want to run a 63A RCD Garage unit CU from it ,the fuses that are in are 20A double fuse holders , the feed to these is a 10mm2 4 core swa ,the earth is via the armour .
The problem is that there is not enough room in the bottom feed in to the 20A fuse holder to take the 10mm2 that is in , and another 10mm2 I need to take the feed from .
Anyone have a idea how it can be done , I was thinking of using a Henley block in some way , I could of course change the whole DB box , but at this moment I need a easier way if not temp way at the moment ,
kbrownie
Re: 3 Phase Fused Distribution Box in and 63A RCD in Garage
by kbrownie » Sat Oct 29, 2016 10:17 pm
Who is undertaking this work, who is inspecting/testings it, who is signing of, who is applying to the council for notification of work????
Magnet
by Magnet » Sun Oct 30, 2016 6:45 am
kbrownie wrote:Who is undertaking this work, who is inspecting/testings it, who is signing of, who is applying to the council for notification of work????
1st answer : A qualified C&G Electrcian , 2nd A qualified C&G Electrcian 3rd A qualified C&G Electrcian , 4th A qualified C&G Electrcian .
PS: it does not come under part "P"
kbrownie
by kbrownie » Thu Nov 03, 2016 6:56 am
If the garage electrical installation is part or connected a domestic dwelling it come under part p, as all domestic electrical work does!
If the garage is not part/connected to a domestic dwelling I assume it can only be a commercial/industrial project.
With respect to the electrician that you are employing to undertake the work, they really are the best person to ask/answer you questions, as they will see the installation in full.
It is currently Mon Jan 13, 2025 12:00 am
