Which Side of Washer That's Leaking into Cupboard Below
Zacccc
by Zacccc » Sat Oct 29, 2016 5:49 pm
I've just found that water is leaking from the kitchen sink into the cupboard below. It's leaking from where the hot tap is, so I've taken it off and am just replacing it with a new washer. The washer is smooth on one side and has little raised lugs on the other. Could someone advise please on which side of the washer should touch the bottom of the tap and which one the top of the sink. Thanks.
lets have a look
Re: Which Side of Washer That's Leaking into Cupboard Below
by lets have a look » Mon Oct 31, 2016 5:24 am
the lugs bit goes on the bottom
Zacccc
by Zacccc » Mon Oct 31, 2016 6:45 pm
lets have a look wrote:the lugs bit goes on the bottom
Thanks for your help.
It is currently Wed Nov 27, 2024 4:01 am
