Next Lana Lights Keep Turning off After an Hour
Spanner_Dad
by Spanner_Dad » Sun Nov 06, 2016 8:30 pm
I installed a new set of lights from Next about a month ago called Lana. They are supposed to use 20 Watt G4 bulbs, I made the mistake of putting in 25 Watt bulbs in and it seems to have created a problem. Despite restoring the 20 Watt bulbs, the lights now go off after about an hour. Can anyone suggest what could be the issue and how I can resolve this please?
kbrownie
Re: Next Lana Lights Keep Turning off After an Hour
by kbrownie » Mon Nov 07, 2016 11:19 pm
G4 lamps, would suggest 12V transformer.
Transformers normally have a maximum rating, as you have exceeded the required/maximum rating as instructed by the manufacturer, by using 25W lamps instead of 20W lamps, You could have overloaded the transformer, it could well now be that you need to replace it.
It is currently Sun Jan 12, 2025 10:23 pm
