Help Needed in Choosing a Portable Angle Grinder
Fido-X
by Fido-X » Sat Nov 12, 2016 7:17 pm
Hello everyone, i'm gonna buy a new angle grinder and i'll use it mainly for CUTTING METAL.
I already have one old 9 in (230 mm) angle grinder which i use for grinding, sanding and cup steel brush.
I want my new angle grinder to be:
- Manufactured by: BOSCH PROFESSIONALL or MAKITA or METABO (i don't trust in BOSCH HOBBY)
- Robust, powerfull, corded, portable
- I want minimum cutting disc diameter size to be 7 in (180 mm)
The metal i'm gonna cut is gonna be:
1. STEEL bars, pipes and sheet metal (most materials i work with is steel)
2. CAST IRON
3. INOX
4. ALLOY STEEL (rarely found)
SO I'D LIKE TO KNOW SHOULD I BUY A 7 in (180 mm) or 9 in (230 mm) ANGLE GRINDER.
WHICH ONE OF THEM IS BETTER FOR CUTTING?
Thanks in advance.
john_ardia
Re: Help Needed in Choosing a Portable Angle Grinder
by john_ardia » Thu Apr 06, 2017 6:23 am
Most probably Milwaukee Power Tools 2680-20 is a good fit for you. For details look for the specification.
collectors
by collectors » Wed Apr 12, 2017 9:21 am
I found Ryobi to be very reliable & tuff tools. Worth a look at around £65.00 is:
Ryobi EAG2000RS 9-inch Angle Grinder with Rotating Back Handle, 2000 W
As you might know, the blades are the most important thing with any cutter.
It is currently Thu Nov 21, 2024 6:04 pm
