Paint Won't Dry After Chimney Re-Rendering
preale
by preale » Sun Nov 13, 2016 9:00 pm
Two weeks ago I had my chimney re- rendered. This weekend seemed like a decent time to paint it (relatively mild for the time of year and not a bad forecast). I used a water based Weathershield white masonry paint. It went on well and the instructions said it should be ready for a second coat in 3-5 hrs. Sadly after 3hrs it started raining but I thought it might be ok. I checked it this morning - 10 hrs later and it was as wet as when I first applied it. Clearly I should have used an oil based paint which I think could have resisted the rain.
My problem is that I only have 2 weeks left to rectify this until the scaffolding comes down and I can only work at weekends. Assuming the paint is still "wet" next weekend - is there anything I can do to "cure" it or "seal" it perhaps in readiness for an oil based coating if I can get it dry enough??
Re: Paint Won't Dry After Chimney Re-Rendering
by welsh brickie » Tue Nov 22, 2016 6:03 pm
mix pva in the paint, it should dry.
It is currently Fri Nov 15, 2024 3:23 pm
