Which is Cheaper - Gas or Electric Hob in new Kitchen?
6 posts   •   Page 1 of 1
mraich
by mraich » Sun Nov 13, 2016 11:10 pm
Planning for a new kitchen in a new extension. Don't know whether to choose an electric hob or a gas hob. Any advice on which is cheaper to run is appreciated.
Thank you.
mrh
vidwiz
Re: Which is Cheaper - Gas or Electric Hob in new Kitchen?
by vidwiz » Mon Nov 14, 2016 1:37 pm
It's usually gas that works out cheaper and it's better to cook with because it's a lot more controllable.
Many cookers have gas hobs and electric ovens which is probably the best way to go.
kbrownie
by kbrownie » Mon Nov 14, 2016 1:42 pm
Gas will be cheaper to run than electric.
mraich
by mraich » Thu Nov 17, 2016 9:56 pm
[quote="kbrownie"]Gas will be cheaper to run than electric.[/quote]
Thank you, kb.
mraich
by mraich » Thu Nov 17, 2016 9:59 pm
[quote="vidwiz"]It's usually gas that works out cheaper and it's better to cook with because it's a lot more controllable.
Many cookers have gas hobs and electric ovens which is probably the best way to go.[/quote]
Thank you, vidwiz.
by ericmark » Sun Nov 20, 2016 12:37 pm
With a modern electric induction hob, all the power goes into the pan, non into the kitchen, so although gas per kWatt/hour is cheaper, with gas much of the heat goes into the kitchen not into the food. So very likely electric induction is cheaper than gas to run.
I did an experiment, daughter has gas and I saw her boil a kettle then fill the pan, I asked why she did this, she demonstrated how her 2.8kW kettle was faster than her 5.5kW gas hob. So on return home I repeated the experiment with my induction hob, 2.8 kW kettle and 3 kW hob took the same time.
This means that over half the power from a gas hob is wasted, so likely they will work out about the same price to run as gas is so much cheaper.
However electric is now more controllable as long as it has knobs, not a silly touch control, The touch control spoils many electric hobs, they are slow to react, hard to see specially if in a wheel chair, may look good, but are useless to use.
However the rest of the features that come with induction hobs are good, auto switch off when pan is removed, auto switch down or off if over heated, surface cooler so less likely to burn, auto boil then simmer, no naked flame, completely flat so less chance of a pan tipping and falling, easy clean, will not blow out even if set low enough just to melt chocolate.
It is currently Wed Jan 15, 2025 9:32 am
