Hot Water Towel Rail with 2 Water Circuits?
bigjr
by bigjr » Thu Nov 17, 2016 12:18 pm
I have a bathroom with limited wall space only sufficient for either a radiator or a heated towel rail. My oil fired boiler output is divided between a pumped central heating circuit and a separately pumped primary hot water circuit.
Does anyone have knowledge of where I can get a hot water towel rail that I can connect to the pumped hot water circuit but that also has a radiator panel in the centre that I can connect up to the central heating circuit. There has to be no crossover of water between the circuits.
I know dual fuel heated towel rails are available (hot water with an electric element) but was hoping to use a towel rail incorporating the 2 hot water circuits.
It is currently Sat Jan 11, 2025 8:04 pm
