Building a Base for a Concrete Cupboard
fatfei
by fatfei » Wed Dec 07, 2016 1:15 pm
I want to have a go at building a concrete base to build a brick cupboard outside backing onto an extension. It'll be 2ft by 6ft ... Not sure what depth I'll need. How many bags And what type do should I get?
Re: Building a Base for a Concrete Cupboard
by welsh brickie » Wed Dec 07, 2016 6:02 pm
you will need bags of concrete mix, cement and a concrete mixer which you can hire. you can either dig out and lay a foundation or lay it above ground.
I would build a timber frame work on compacted level ground, And fill it with concrete.
The depth of the concrete should be a minimum of 100mm thick, A ton of concrete mix is needed and 8 cement
fatfei
by fatfei » Thu Dec 08, 2016 11:20 am
welsh brickie wrote:you will need bags of concrete mix, cement and a concrete mixer which you can hire. you can either dig out and lay a foundation or lay it above ground.
Thanks Welsh brickie
It is currently Fri Nov 22, 2024 10:58 am
