Earthing new Light Fittings and Blowing Circuit Breaker
Tima52
by Tima52 » Thu Dec 08, 2016 7:56 am
I just replaced two light fittings in my bedroom cupboards both on the same light circuit. The new fittings have an earth terminal on them which I connected up OK. The first one works fine but the other one throws the circuit breaker out as soon as I energise the light circuit. If I disconnect the earth wire to it though it then works fine.
Has anyone any clues as to why it won't work with the earth connected?
Perhaps a faulty fitting?
Tim
kbrownie
Re: Earthing new Light Fittings and Blowing Circuit Breaker
by kbrownie » Thu Dec 08, 2016 5:20 pm
You need to test the earth is not live!!!!!
It is currently Sun Jan 12, 2025 7:04 pm
