hundreds of cracks in paint
robert0881
by robert0881 » Sat Aug 18, 2007 11:51 pm
ive painted my hall with dulux mat emulsion and when it has dried it has come up with hundreds of tiny hairline cracks over it that resemble aligotors skin. i tried putting another coat of paint on but this had just done the same. the wals were perfect before i started. and its the paint that has cracked not the walls. any advice on what to do?
kekec
by kekec » Mon Aug 20, 2007 9:57 am
Have you checked the paint that was on before - if it was silk emulsion(slightly shiny finish) and you are trying to put matt emulsion over it, will get that cracking effect due to reaction between two paints. The remedy is to use basecoat (B&Q own or Polycell) to seal the surface and when dry paint over with matt.
It is currently Fri Nov 22, 2024 11:54 am
