Bathroom basin mixer taps with low pressure hot water
DeanThomas
by DeanThomas » Fri Dec 23, 2016 6:11 pm
we have just had the tap installed, it said on the description that it was high and low pressure, the cold comes out quite fast as per the old one, but the hot has not much pressure , was there something the plumber should have changed on the tap, to change it from high to low pressure .
collectors
Re: Bathroom basin mixer taps with low pressure hot water
by collectors » Sun Dec 25, 2016 4:22 pm
not lightly, but the flexible hoses that come with the taps can come with different bores. The other possibility is the cold is off the mains water & the hot is off gravity from a tank. if this was the case the mains cold would be fine, but the hot would be slow.
DeanThomas
by DeanThomas » Wed Dec 28, 2016 10:05 am
the cold and hot are both fed by gravity , I will check the dia of flexible hoses . many thanks for help
It is currently Sat Nov 23, 2024 1:54 am
