Brick crumbling and slight leak when after heavy rain
markarm
by markarm » Tue Dec 27, 2016 12:18 pm
Hi all,
Problem with chimney stack last year, and quite a wet chimney breast in the loft just on one side.
We had a roofer out and he flaunched the chimney, put some covers on the chimney to stop rain coming down through chimney and re-pointed some of the stack, he also tagged a couple of slates but the roof was in very good condition. This seemed to sort the problem out for a while but a small drip occurs after heavy rainfall.
i went into the loft and found that the brick on the chimney stack is crumbling (as it was last year, just one side of the house) and the mortar is dry and loose. There are a couple of bricks missing also!
I have read about salting, is this the cause?
I did read that if you have a problem with your chimney you should get a chimney specialist and not a roofer!
Any advice would be welcome. I have a video of the loft and chimney but unsure if if will upload on here. will try though
Many thanks in advance
mark
Re: Brick crumbling and slight leak when after heavy rain
by welsh brickie » Tue Dec 27, 2016 9:01 pm
If its the brickwork, then you can get a silicone spray to seal the brickwork,
It could also be the flashing around the chimney. A roofer is capable of doing the work
markarm
by markarm » Fri Dec 30, 2016 4:26 pm
Hi Welsh brickie
Ta for the answer i have a roofer who is going to take a look at the flashing and chimney and will also assess the chimney in the loft to see if it just needs a few new bricks/faces and a deep soft mortar on the joints.
heres a pic of the breast
It is currently Mon Nov 25, 2024 7:43 am
